Subject Index
Symbols (monetary & etc.)
†, 37
◊, 37
‡, 37
…, 37
in Find/Replace, 465
₥, 37
searching for, 471
฿, 37
searching for, 471
₨, 37
searching for, 471
‰, 37
₩, 37
searching for, 471
™, 37
₪, 37
searching for, 471
€, 37
searching for, 471
in Find/Replace, 471
$, 37
as Find/Replace metacharacter, 477
searching for, 471
ﷺ, 668
ƒ, 37
searching for, 471
‽, 37
¡, 37
¢, 37
searching for, 471
﷼, 37, 668
searching for, 471
£, 37
searching for, 471
plus as Find/Replace metacharacter, 477
¤, 37
¥, 37
searching for, 471
hyphen as Find/Replace metacharacter, 477
¦, 37
⁂, 37
§, 37
©, 37
®, 37
°, 37
¶, 37
swung dash, 668
:backslash as Find/Replace metacharacter, 479
¿, 37
۩, 668
﴾, 668
﴿, 668
ʾ, 37
ʿ, 37
 ؑ, 668
 ؒ, 668
 ؓ, 668
hyphen, 668
non-breaking hyphen, 668
figure dash, 668
en dash, 668
em dash, 668
#10 Envelope (paper size), 168
quotation dash, 668
A
A4 (paper size), 168
A5 (paper size), 168
abbreviation
Glossary, 581, 584–585
in Find/Replace, AnySentence, 471
QuickFix, 581
above
in cross-reference, 310
paragraph spacing, 31, 124
tables, add row to, 273
address
for envelopes, 648–649
in bidirectional text, 46, 670
in Find/Replace, 458
after, paragraph spacing, 31
align, 121, 124, 709
as an aspect of styles, 137
columns with tabs, 129, 135
images, 214–215
in headers/footers, 185
page numbers in tables of contents, 318–319
paragraphs, 121
tables, 270, 280
text within, 270–271
decimal point, 271–272
alphabetize
all words in document, 335
rows of a table, 273
sorting paragraphs, 428
anchor
display of, 211
in floating images, 210
in floating shapes, 211
moving the, 211
AppleScript, 641
AppleWorks, 77
Arabic, 37, 718
displaying character forms, 709
number formats, 63
numbering, 63
numerals in lists, 691
preferred encoding for saved files, 603
typing right to left text, 44
arrowheads, 235
arrows
add to document, 234
and the shape stroke palette, 235
block arrows, 236
color of, 234
ASCII, 440, 477, 480–481, 483, 705–706, 708, 718
Asian, East
convert scripts, 664
expanding glossary abbreviations for, 585, 663
indexing, 326
space (Unicode U+3000), 589
vertical text, 229
asterisk (*)
as footnote/endnote marker, 261
as mathematical operator, 633
in calculate macros, 633
in Find/Replace, 482
punctuation character, 481
Asterism, 37
attribute sensitive. See: Find/Replace
automatic
check for new versions, 567
glossary expansion, 585
incrementing numbers, 671
coloring, 573
cross-reference to, 310
footnotes & endnotes, 257
lists, 59, 66
cross-reference, 67
pages, 182, 184, 187, 189
pagination, 182
sections, 187, 256
stop, 141, 691
index
from word list, 335
generate topic, 328
palettes appear, 26, 181
reopen windows, 548
save, 3–4, 452, 455, 601
naming, 599
style set to following paragraph, 147
superscript ordinals, 582
table of contents creating, 314
tabs (built in), 129
text, coloring of, 573
view switching, 462
Automatic Numbers, 190
autosave, 74
AutoText. See: Glossary
B
B5 (paper size), 168
Baht, 37
before, paragraph spacing, 31
below
bibliographical tools, 345
bidirectional
Arabic, Hebrew, Ladino, Pashtun, Persian, Urdu, Yiddish, 44
directionality marker menu, 670
mixing right to left and left to right text, 46–47
reverse direction marker, 589
Body Text style. See: Normal (style)
Bookends, 345–346, 348, 350, 352
bookmarks, 299
automatically named, 300
explicitly named, 301
highlights for, 575
jumping to, 305
moving, 307
removing, 307
search by name, 305
setting, 300
as something else, 301
use to create table of contents, 322
viewing in list (Navigator)
alphabetically, 304
by location, 305
border
page, 178–180
pleading page, 417
paragraph, 433, 435, 438
table, 285
table cell, 288–289, 291–292
bottom
alignment
of floating images, 214
text in tables, 270
lines in tables, 289
margin, 173
bounding box
of grouped shapes, 241
of lines, 216
shapes and images, 213
bring to front
shapes, 238
Broken Bar, 37
Bulgarian
searching for text in, 466
Bullet, 37
bullet
in this User's Guide, iii
lists
highlight coloring, 573
C
Canvas, 247
capitalize
change case, 440
display as, 687
find, 461
caption
automatic numbering of, 66
keep with illustration, 129
caret
(^) in Find/Replace, 480–482
selection (insertion point) color, 576
case sensitivity, 326
changing case, 440
Character Case (display) Commands explained, 686–687
Convert Commands explained, 663
in Find/Replace, 446–447, 458, 461–462, 471, 480–482
in macros
commands in, 631–632
names, 631
in tables, selecting using keyboard, 269
in the index, 326, 335
section separators, 339
in user dictionary, 391
spelling checker ignores, 388
typing accented characters, 713
cells. See: tables
Cent, 37
center, 121
alignment, 121
decimal tab in tables, 271
tab, 130
tables, 268, 270
decimals, 271
expansion, 280
text in, 270–271
centimeters, 588
Central European
character
styles
new, based on selection, 149
character formatting, 101–102
check mark
in dialog box, 13
menu command followed by, 8, 668, 685
Chinese, 229, 664
convert asian scripts, 665
numbering, 64
vertical text, 229
Clipboard, 56
append cut, 55
append to, 53
bypassing in Find/Replace, 443
choosing, 58
contents not saved, 607
copy attributes only, 54
copy text only, 53
copy to, 53
customize, 607–608
edit contents of, 56
import graphic using, 200
import table data using, 268
in macros
Perl, 639–640
menu on the Statusbar, 53
new, 59
rename, 59
Tag on the Statusbar, 18
color, 431
automatic numbers, 573
automatic text, 573
Background, 432
comment author color, 574
comment sidebar color, 574
cross-references, 573
cross-references, stale, 573
draft background, 574
draft view text, 574
Find/Replace "bubble", 458, 573
full screen background, 574
full screen caret (insertion point), 574
full screen gutter, 574
full screen text, 574
Highlight, 431, 688
highlight
bookmarked text, 575
indexed text, 575
tables of content, 573
text in the table of contents, 575
in AppleScript, 641–642
in line numbers, 412–413
in paragraph borders, 436
in paragraphs
shading, 437
in styles, 137, 594
inheriting, 146
in tables, 288, 291
cells, 292, 294–295
guides, 291, 575
lines (edges, borders), 288
in the Dropper, 111
indexes, 573
invisibles, 425, 574
list items, 573
merge placeholder, 573
Navigator background, 574
note references, 573
of lines, 234
of shape anchor, 575
of shape bounding box, 575
of shape paste spot, 575
on the Character palette, 29
page, 574
page backdrop, 574
page frame, 574
page guides, 574, 591
remove attributes, 428
selection
active, 575
caret (insertion point), 576
check spelling, 576
expand QuickFix, 576
Find/Replace, 444, 576
flash, 576
in spelling checker, 388
inactive, 576
rectangular, 576
shape fill, 242
strikethrough, 687
substituted font, 575
Tag
Background Color on the Statusbar, 20
text, 431, 688–689, 700–701
the Colors panel, 291–292, 295, 431, 572, 590, 592, 594
columnar selection. See: rectangular selection
columns, 175–176
balance text in, 176
Columns palette, location of, 26
create word list for indexing, 336
finding, 481
gutter width, 175
in tables
adding, 272
aligning, 271
equalizing widths, 281
fitting to contents, 283
headers, 266–267
merging, 274
number of, 266–267
removing, 273
row header, 286
selecting, 269
sorting, 428
splitting, 277
line between, 175
per section, 256
prevent text from breaking across, 32, 128–129, 689
rectangular selection, 51
selecting text in, 51
set number of in section, 175
swapping macro, 336
using tabs to align, 129, 132
using tabs to create, 710
when visible, 355, 424
comment, 497, 499, 501, 506, 517–518
add to existing, 518
color of, 573
display particular author's, 519
hide, 506, 513
highlight in text, 507
history, 505, 509
location of pane, 512
minimize sidebar, 517
number of in document, 517
reposition, 512
review history, 518
show, 506
style of, 683
text received from others, 517
title bar of, 574
contextual menu
Check Spelling, 386–387
Copy Hyperlink, 645
Edit Hyperlink, 646
Footnotes/Endnotes, 257
Images, 209, 211
Index, 338
Open Hyperlink, 645
Table of Contents, 317
Thesaurus, 393
contextual menu
contextual menu, 85, 88, 95–96, 98–100, 209–211, 213, 257, 313, 316–317, 338, 386–387, 390–391, 393, 645–646
control key, 13
in Menu Keys, 578
copy, 53
append, 56
attributes only, 54
formatted text, 57
graphics, 196
in dialog boxes, 13
in Find/Replace window, 465
styled text, 57
tables, 296
text only, 54
text with attributes, 57
conflicts, 153
to Find, 443
to Replace, 443
Copy Commands explained, 661
Copyright, 37
Corner Bracket, 37
cross-reference
add, 310
broken references, 311–312
find bookmark from, 312
highlight text in, 573
in indexing, 328, 330–331
in the index, 340
source. See: cross-reference target
target, 308–309
to automatic incrementing list item, 67
use to create table of contents, 321
Cross-reference, 308
Cross-references, 308
CSV, 551
curly quotes. See: quotes
currency
searching for, 471
Currency, 37
customized palettes, location of, 567
cut
append, 55
in dialog boxes, 13
Cut Commands explained, 661
Cyrillic
D
Dagger, 37
dash. See also: hyphen and/or minus sign
in menus, 657, 685
leader, 132, 319, 340
Dashes, 37
date
in Find/Replace, reorder pattern, 472
sort by in Document Manager, 78
Date & Time Variables, 190
decimal tab, 130, 132, 271
defaults
color of active selection highlight, 575
color of inactive selection highlight, 576
display of Palette Dock, 78
Document Manager as Save location, 84
for application and new files. See: templates
format of saved files, 603
groups in the Document Manager, 88
in ligatures, 688
in Perl macros, 639
in the Background Color submenu, 689
in the Highlight submenu, 688
in the Text Color submenu, 242, 688, 700–701
Index, 697
language of the Nisus New File, 43
location of the Document Manager folder, 83
location of the Header/Footer palette, 182
palette sets in the Palette Dock, 25
paper size for printing, 168
resolving conflicts between pasted styes, 153
set for application, 1
set of tools on the Toolbar, 612
settings of the Image palette when set to Fixed on page, 209
style of heading in Index, 339
style of paragraph levels in Index, 340
styles associated with Table of Contents, 319
Table of Contents, 696
templates. See: templates
templates and the Document Manager, 660
when setting the baseline, 429
when using ligatures, 429
Degree, 37
delete. See also: remove
attributes from style, 144, 148
Clipboards, 608
files from Open Recent menu, 659
Glossary entry, 585
Glossary file, 585
header/footer, 186
hyperlink, 646
index, 338
keyboard shortcut, 579
license, 658
palettes, 622
saved Find or Replace expression, 456
section break, 189
table of contents, 317
tables, 296
rows and columns from, 272–273
text, 55
typo from QuickFix, 583
dialog boxes, 13, 657
dingbat, 37, 339, 471, 705
searching for, 471
disconnected selection. See: multipart selection
division (/) sign, in macros, 633
.doc, 608
document
autosave, 74
export, 76
file format, 74, 76
insert, total page number of current, 671
Microsoft Word, 76
properties, 409
rename, 75
save, 74
size, 76
versions, 603
Document Manager
add file to, 87
additional features of, 99
commands of File menu, 660–661
create/display
special groups in, 89–93, 96
display
and sort files in, 88
file types in, 84
find files using, 83, 97
first use of, 80
folder
set location of, 83
maintain a style library using, 136, 157–158, 164–165
managing files using, 73
move file to, 85
open files using, 1–2, 99
open from
Dock menu, 9
Window menu, 10
preferences of, 83
save files
as needed to, 84
automatically to, 84, 599, 602
with new name to, 84
see preview of file in, 97
set file listing options of, 83
Spotlight with, 92
Style Library commands, 670
using custom Toolbar items with, 612
Document Properties, 190
document versions
browser, 604
delete prior versions, 605
listing, 603
open versions, 604
revert to a version, 604
.docx, 608
Dollar, 37
Double Dagger, 37
double spacing lines, 124
Dropper, 111
dumb quotes. See: quotes
E
e-book, 77
Ellipses, 37
Em Dash, 37
Empty Page, 184
En Dash, 37
endnote, 257. See also: footnote
bookmarks in, 305
change to footnote, 262
cross-reference to, 309
edit, 257
highlight color of, 573
in tables, 296
insert, 257
line numbers in, 411
Notes Tag on Statusbar, 20
prevent lines from spreading when using, 125
restart at assigned page number, 263
return to
document from, 257
note from its marker, 257
style of, 138–139
tables in, 296
envelope
format and print, 648–650
page setup paper sizes, 168
EPS, 198
EPUB, 77
esreveR, 718
Euro, 37
F
facing pages, 173, 184. See: margins
fallback font, 108
Farsi
Figure Dash, 37
find. See also: replace
Find/Replace, 443–444, 446, 452, 455–461, 463–474, 477–484
attribute sensitivity in, 447
by style, 150
case sensitivity, 446–447
find all, 443
format sensitivity in, 446
in tables, 296
index multiple items as one, using, 328
index text patterns using, 334
invisibles in, 442
limit the replace
attribute sensitive, 447
limit the search
attribute sensitive, 446
case sensitivity, 462
whole word, 446
next, 443–444
Normal Find, 443–444, 446–447
PowerFind, 458–459, 461–463
PowerFind Pro, 463
previous, 443
replace, 444
replace all, 444
replace and find, 444
first line indent, 65
Flesch Reading Ease, 407
Florin, 37
FOG Index, 407
font, 2
adding to your System, 109
changing, 103
check marks on menu, 657
defined, 706
dingbats, 705
Display as Small Caps, 687
Font
menu, 103, 571, 684
WYSIWYG, 107
panel, 593
Tag on the Statusbar, 20, 103, 107, 110
Font "Family" on the Character palette, 28, 103, 107
how Nisus Writer Pro displays, 709
in AppleScript, 641
in style sheets, 136
index text in, 333
kerning, 707
ligatures, 429, 688, 707, 709
limitations, 29
monospaced, 710
of index, 340
section separator, 339
of Nisus New File, 593
panel, 685
previews, 107
removing attributes, 152
substitution, 108
color, 575
Unicode, 708–709, 716
using styles, 137
character, 137
formats
inheriting, 145
paragraph, 137
writing in multiple languages, 40, 42, 46
Classic, 718
right to left, 46
font substitution, 108
footers, 181–189
and bookmarks, 305
change location of, 186
creating correspondence stationery, 648
deleting, 186
different each section, 184
different first page, 184
Draft View & Full Screen view, 424
editing, 185
even numbered pages, 184
"First Page Special", 184
Header/Footer palette, 183
hiding, 186
images in, 185
in relation to the margin, 173
odd numbered pages, 184
page and section numbering with, 187
Page Guides, 591
page numbering, current and total, 189
palette
location of, 26
pointer variation, 11–12
same for all pages, 182
shipped style for, 138, 683
tables in, 296
footnote, 257
bookmarks in, 305
change to endnote, 262
in tables, 296
index text in, 326
insert, 257
restart at assigned note number, 263
return to
document from, 257
style of, 138–139
tables in, 296
Footnote
symbols available, 63
format
characters, 105, 107, 111
font, 107
other attributes, 110
override, 111
size, 107
documents
style sheets, 136, 138, 144, 147–148
conflicts, 153
remove, 152
style library, 154–155, 157–159, 161–162, 164
import files, 608, 658
of saved files, 603
paragraphs, 112, 114, 116, 119, 124, 128–129, 135
G
garosseugi, 229
glossaries, location of, 567
Nisus Writer Classic, 718
Greek, 37
gremlin, 589, 706
GREP, 707
group
shapes, 238
Guillemet, 37
gutter
full screen view, 574
in columns, 175–176
in line numbers, 413
in margins, 173
H
Hair Space, 37
Half Ring, 37
hanging indent, 65
Hangul, 229. See: Korean
headers, 181–187, 189
and bookmarks, 305
deleting, 186
editing, 185
for printing envelopes, 648
hiding, 186
images in, 185
in tables, 285–286
Page Guides, 591
page numbering restart, 189
page numbers, current and total, 189
palette
location of, 26
shipped style for, 683
tables in, 296
Hebrew, 37, 718
numbering, 63
hengpai, 229
highlighting, 572
Hiragana, 332, 334, 466–467, 664
hoengseo, 229
Horizontal Ruler, 14
HTML, 475
background color saved for, 432
edit documents, 646
export, 77
export ("save") as, 646
view documents, 646
hyperlink, 644, 646
intra-document, 311
hyphen, 37, 396
and To Capitalized, 440
in Find/Replace
phone numbers with, 477
user-defined wild cards [∑], 481
in indexes, consecutive pages, 344
hyphenation
TeX hyphenation patterns, 395
I
I-beam. See: insertion point
Icelandic
text encoding of saved files, 603
ideographic languages
Expand Glossary, 663
images, 195, 215, 245
align, 214
and line height, 196
borders, 205
bounding box, 213
cause inline to float, 209
convert to text, 202
crop, 204
Cross Hairs in relation to, 12
deleting, 207
export, 201
file name, 202
floating, 197, 207
alignment, 214
anchor, 210–211
contextual menu, 212
text wrap, 215
floating to inline, 221
Grabbing Hand in relation to, 12
import, 198
formats supported, 198
in tables, 268
inline, 196
largest in size, 199
Markup, 206
metadata, 202
opacity, 204
padding, 204
resize, 203
restore original size, 203
restore proportions, 204
text on top or behind, 219–220
text wrap around, 209, 215, 218
import
files of different format, 608
inches, 588
indent, 112
alignment, 121
Block Quote supplied style, 138
computer/typewriter difference, 710
first line, 112–114, 116
hanging, 114
in lists, 115
in right to left text, 45–46
in styles, 137
inheriting, 145
line wrap, 116–117
markers on the ruler, 112
selecting on ruler, 117
set numerically, 119
set using keyboard, 120
using the button, 114–115
with differently formatted paragraphs selected, 135
index, 326–330, 332–336, 338–344
all occurrences, 332
case sensitivity in, 326
consecutive page numbers, 344
create, 326
new, 341
cross-references, 330, 340
formatting, 339–341
hierarchical, 332
highlighting text in, 336
in footnote text, 326
Index As
additional, 332
internal difference, 327
Indexing palette, 343–344
location of, 26
inserting in document, 338
jumping to text, 344
mark text for, 326
overlapping entries, 334
remove entries, 336
removing from document, 338
search, 344
updating, 338
using
Find/Replace, 328
Style Sheets, 333
word list, 335
Index Commands explained, 696
index,Japanese, 334
indexed, 336
inline image, 196
import, 200
make floating, 207
insertion point
blinking, 570
text entry, 12
width, 570
install Nisus Writer Pro, iv
Internet
getting support for Nisus Writer Pro, 704
interacting with, 644
Interrobang, 37
invert selection, 51
Inverted Exclamation, 37
Inverted Question Mark, 37
invisible, language as an invisible attribute of text, 40
invisibles
Appearance preferences, 574
characters explained, 714
Find/Replace, 483
identified, 589
illustrated
all characters, 590
tab & paragraph formatting, 132
decimals in tables, 271
in Find/Replace, 468
null character, 477
printing, 558
Show Invisibles
as an aid to typing, 46
available in Find/Replace, 442
color customizable, 589
saved with file, 606
iroha, 64
J
Japanese, 229, 332, 334
convert asian scripts, 664
numbering, 64
vertical text, 229
Jawi, 49
jongseo, 229
JPEG, 198
justify text, 121, 124
in tables, 270
K
Kanji, 64, 332, 334, 412, 664
numbering, 64
Katakana, 64, 664
keyboard
creating PowerFind Pro expressions, 458, 477
enter
invisible characters using, 714
unusual characters using, 714
Yiddish, 715
Flag menu, 710
in tables
navigate among cells, 269
remove table, 296
select cells, 269
Input Menu, 710
Keyboard Viewer, 712–713
language switching, 40
modifier keys, 13, 578, 712
move tab indicator using, 135
navigate using, 51
in table cells, 269
nudge images using, 214
select text using, 51
in tables, 269
set text wrap area using, 120
shortcuts, 13
assign, 578
Complete, 663
conflicts, 579
Expand Glossary, 585
remove, 579
set in Style Sheet view, 144, 147
switch languages, 44
spelling
correct using, 385
Spelling window, 389
switch languages, 46
error, 47
type unusual characters using, 712
keyboard shortcuts, location of, 567
Klingon, 49
Korean, 229
vertical text, 229
L
Ladino
landscape
orientation, 169
language
affect on, when character style applied, 137
alphabetic characters defined for Find/Replace, 483
as an attribute of text, 40
Asian, East, 663
Expand Glossary command, 585
space character, 589
bidirectional, 44
direction markers, 589, 670
Cyrillic, 40
default, 593
ideographic, 40, 663, 707
invisible space, 589
index all words in particular, 333
interface translation, 579
Language palette
change using, 25
check spelling, 384, 386–387
location of, 25
Language submenu, Commands explained, 684
Language Tag on the Statusbar, 20
Languages preferences, 40–41
other than American English, 2
Paragraph Writing Direction submenu Commands explained, 689
QuickFix, 581
romanic, 40
typing unusual characters, 710
Unicode, 40
writing in multiple languages, 40–41, 43–48
alternate spelling dictionaries, 394
change, 44
using Language button on Toolbar, 14, 43
using Language pop-up menu of the Language palette, 43
using Language Tag on the Statusbar, 43
using styles, 136
right to left, 2, 44, 46–47
direction
alert, 45
determined by language, 593
markers, 589
mixing, 46
Paragraph palette change direction using, 30
tables, 48
secondary font, 42
set up Nisus Writer Pro, 40
set up your Macintosh, 716
thesaurus, 42
word count, 42
Language palette, 391
leader tab, 130
leading, 124
left
alignment, 30, 121–122, 689
images, text wrap around, 214
tables, 268, 270
expansion, 280
indent marker, 116, 120
tab, 130, 132
tables
add column to, 273
lines, 289
row header, 286
license, vi, 658
line height, 124
line numbers, 411–413
commands explained, 681
continue from previous section, 411
continuous, 411
display interval, 412
font/size/style of, 413
format, 413
gutter for, 413
margins relative to, 411
per section, 411
prevent display, 411
printing, 411
restart per page, 411
start from, 412
line spacing, 124–125
line wrap, 116–117
lines
and the Shape Stroke palette, 234
color of, 234
numbering. See: line numbers
link. See: hyperlink
LinkBack, 200, 643
list
font, 107
index using word list, 335
Undo/Redo, 70
list item, 59
list item flavors, 65
list levels, 62
list styles, 59
lists
alphabetizing, 428
cross-reference to, 310, 377
customize color of, 573
explained, 60–61
in the User's Guide, iii
incrementing
figure captions, 66–67
indenting, 115
List
button on Toolbar, 61
Tag on the Statusbar, 19, 149
sorting, 428
styles, 59
in Style Sheet view, 138
Paragraph styles override, 137
remove formatting, 428
lowercase. See also: case sensitivity
convert to, 440, 663
display as, 686
Lozenge, 37
M
macros
AppleScript, 641
automatically index using
Analyze Text, 336
Create Word List, 335
calculate using
average column, 632
average row, 632
average rows and columns, 632
Evaluate Selection, 633
Mortgage Payment Calculation, 633
stdDev column, 633
stdDev row, 633
stdDev rows and columns, 633
sum clipboard, 633
sum column, 633
sum row, 633
sum rows and columns, 633
Sum Selection, 634
case sensitivity in, 631
defined, 629
file format, 75
files
deleting, 630
editing, 630
location, 630
rename, 630
running, 629
saving, 630
Find/Replace, 456
"macroize", 456
Menu Command dialect, 632–634
Perl dialect, 639–640
process notification on the Statusbar, 629
straight quote required for, 440
typing commands, 631
undo effects of, 630
macros, location of, 567
margins, 171–174
envelopes, 648
header & footer location, 185
images bleed beyond, 245
indents & line wraps measured from, 112
line numbering relative to, 411, 681
lock, 171
Margins palette, location of, 26
mirrored, 174
pointer variant, 12
reflected (odd, even pages), 184
set by increments, 174
set numerically, 172
set visually, 171
vary per section, 256
viewed with Page Guides, 591
Markup, 206
Math, 37
mathematical characters, 37
mathematical operators, 633
measurement, 588
merge, 550–552
data document, 553
Perl code in, 551
merge placeholders, 549
Microsoft, 76
Microsoft Word, 76–77, 80
field codes, 575
middle alignment (height), text in tables, 270
Mill, 37
millimeters, 588
minus sign
button
in Columns palette, 175
in Indexing palette, 175, 344
remove QuickFix typo, 583
mirror margins, 174
mistakes, fixing. See: Undo
mixed, 26
mouse
right-click, 13
using the, 13
using the
mouse
mouse
mouse
mouse
mouse, x, 7, 9, 12–13, 51, 53–57, 85, 88, 100, 112, 116, 135, 214, 261–262, 267, 269, 296, 379, 386–387, 505, 578, 631–632, 645–646, 669
mouse cursor, 12
multipart selection, 51, 451
N
Navigator
bookmarked text shown
alphabetically, 304
by location, 305
table of contents entries shown, 313
ASCII explained, 705
esreveR style, 718
file opened in Nisus Writer Pro, 709
open multilingual files in Nisus Writer Pro, 718
The Nisus Man, 717
Unicode explained, 708
Non-Breaking Hyphen, 37
non-breaking space, 37
Non-Breaking Zero Width Space, 37
non-printing characters. See: invisibles
non-Roman text
indexing, 334
noncontiguous selection. See: multipart selection
Normal (style), 138, 144–145, 147
note reference, 257
note text, 257
number, 67
automatic
commands explained, 670
in headers/footers, 184
in sections, 256
Clipboard, choose alternate, 58
columns, 175
footnote/endnote, 257
in
cross-references, 322
Find and Replace
finding, 441, 470, 477, 484
Match Set commands, 463
Repeat # commands, 465
Wild Card command, 471
headers/footers, 181
index
cross-reference, 330
footnote/endnote, 326
format, 340
Menu Keys, 578
table of contents, 318
location of, 318–319
updating, 316
tables, of columns/rows, 266
line, 411–413
line numbers display, 355, 424
line spacing, 124
list item in cross-reference, 310
lists, 60–61, 64
commands explained, 691
in styles, 148
note in cross-reference, 310
of
characters, 400
columns permitted, 175
indexes permitted, 341
keys permitted in menu commands, 579
paragraphs, 400
section, 256
tables of contents permitted, 319
tabs permitted, 132
words, 400
page
pages
all, 182
display current and total, 189
displayed in the Page palette, 374
even, 184
format of, 189–190
in document, 187
in index, 344
in section, 187
in table of contents, 318
multiple sections, 184
odd, 184
restart, 188
restart at 1, 188
paragraph, 411
paragraph in cross-reference, 310
paragraph spacing, 126
printing copies, 558
printing page range, 558
section in cross-reference, 310
sections, 187
size of text characters, 29, 108
sorting paragraphs beginning with, 428
numbers
aligning in tables, 271
columns of, 132
instructions in this document, iii
ordinal, superscripted, 125
O
OCR, 201
odd & even pages, 184
.odt, 608
open
any file as new or Untitled, 78
automatically saved files, 602
Clipboards, 608
default file, 586
existing file, 1–2
how files open, 78
in AppleScript, 641
macro folder, 702
new file, 1
Nisus Writer Classic documents, 718
Nisus Writer Classic Glossary, 585
Open Recent menu, 567
palettes, 23
template documents, 167, 586
using Document Manager, 78
optical character recognition, 201–202
orientation
of page, 169
envelopes, 648
orphan, 32, 128, 689, 707
outline, 323–325
P
padding
text wrap around shapes, 218
Page Borders, palette, location of, 26
page break, 355, 422–423, 425, 427, 472, 481
display, 589
finding, 426, 471
insert, 670
remove
in Find/Replace, 472
page count, 374
page, empty (what displays on), 184
pages, insert total number of current, 671
pagination, 422
palette
tools
drag bar, 25, 104, 139, 437
enlarge corner, 25, 104, 139
palettes
Apple-supplied Character, 467
Character, 103–105, 108, 144, 709
Columns, 175–176
create new set of, 622
display, 23
display different set, 24, 26
display in Draft View or Full Screen view, 424
Header/Footer, 181–184
hide, 23
Image, 209, 214–215
Indexing, 343–344
introduction to, 26
Language, 43–44, 46–48, 384, 386–387
Line Numbers, 411–413
Lists, 60
Margins, 172, 174
Page, 374
Paragraph, 48, 121, 123–124, 128, 135, 144
remove, 24
reposition, 24
restore, 24
Section, 174, 184, 188–190, 256
Sections group, 172
Styles, 136–137, 143–144, 149–151
Table, 270, 272–273, 285–286
Table Cells, 270–271, 274, 277, 281–287
Table of Contents, 320–321
paper size, 167–168, 170–171, 648
paragraph
alphabetizing, 428
bulleted lists, 61
floating images move with, 207
formatting character, 589
how Nisus Writer Pro displays your text, 709
in AppleScript, 642
in Find/Replace, 470–471
end of paragraph position, 469
neighboring duplicate, 474
start of paragraph position, 469, 482
the Return character, 468
trailing spaces, 477
indent using the tools on the ruler, 35
index as, 326
invisible character, 589
Paragraph palette
alignment, 121
bidirectional text, 48
using, 32
press return only to begin paragraphs, 35
quadruple-click mouse to select, 51
Ruler Tag on the Statusbar, 21
shading, 437
structuring paragraphs, 112
alignment, 121
in tables, 270
indents, 112
keep together, 128
keep with next, 129
line spacing, 124
same for multiple, 135
tabs, 129–130, 132
leader, 132, 134
moving, 135
removing, 135
text wrap, 116
using styles, 136, 138
applying, 137
removes attributes, 137
widow/orphan control, 128
styles, 136
determine style of next, 147
format index, 338–340
format table of contents, 317, 319
inherit attributes, 145
remove attributes from text, 150, 428
select text with, 150
use for index, 333
use for table of contents, 314
paragraph border
padding, 436
Paragraph Borders palette, 435
paragraph formatting, 101
Paragraph Mark, 37
paragraph numbers
printing, 411
Paragraph Shading palette, 435, 437
Pashtun, typing right to left text, 44
paste, 55
attributes only, 56
formatted text, 57
graphics, 185, 196
in dialog boxes, 13
in Glossaries, 584–585
in tables, 268
tables, 296
text only, 55
text with attributes, conflicts, 153, 569
PDF, 4, 198, 562, 647
export, 76
import, 200
import text, 201
.pdf, 1
Per Mille, 37
Perl
file format, 75
in merge, 551
macros
writing, 639
Persian
Persian, typing right to left text, 44
picas, 588
Plain Quote, 37, 440
Pleading Page, 417
plus (+) sign as mathematical operator, 633
PNG, 198
pointer
choose table size, 267
exit Full Screen, 676
tooltip displayed, 18, 58
variations, 11–12, 172, 278
points, 588
portrait
orientation, 169
PostScript
create document, 563
Pound, 37
PowerFind, 458, 461–463, 465, 467–475
PowerFind Browser, 461
PowerFind Pro, 477–478, 481–484
preferences
Appearance, 107–108
Automatic Text, 572
Dark Mode, 570, 576
Invisibles & Guides, 574
Light Mode, 570, 576
Marked Text, 575
Selection, 575
Show Invisibles, 589
Show Page Guides, 591
Clipboards, 56, 607–608
Doc Manager, 83–84
General, 153, 432, 566
automatic saving, 601
pasted style conflict resolution, 569
text encoding of saved file, 603
Languages, 40, 44
Measurement, 588
Menu Keys, 578
remove, 579
New File, 428, 566, 587, 593–597
opening files, 78
QuickFix
Glossaries, 584–585
smart/straight quotes, 440, 582
typos, 385, 582–583
save preferences, 609
Saving, 599, 603, 606
System Preferences, 43
Appearance, 432
International (languages), 44, 710, 712
set paper size, 168
primary font, 108
print, 4, 555
envelopes, 648
Highlight color, 432
image beyond the margin, 245
in AppleScript, 641
in Demo period, vi
in reverse order, 558
line or paragraph numbers, 411
margins, 171
mirror page placement, 174
non-printing characters, 483, 706
number of copies, 558
odd pages, then even, 558–559
orientation of printed page, 169
output of Perl, 639
page guides and invisibles, 558
printer limits, 173
range of pages, 558
reduce or enlarge printed area, 169
to PDF, 4
to PostScript, 563
punctuation
characters in Find/Replace, 481
searching for, 471
Q
QuickFix
automatic Smart Quotes, 582
fix typos, 582–583
Glossary, 584
QuickFix, location of, 567
quit, 5
AppleScript command, 641
Clipboards, 57, 607
during demo period, vi
Glossary files, 585
open windows, 548
Preference file, 609
recent Find/Replace expressions, 452
saved Find/Replace expressions, 455
Quotation Dash, 37
quotes
block quote style, 138
convert
automatically, 440
plain to smart, 440, 663
smart to plain, 440, 663
text between, 482
in macros, plain required, 440
R
read-only mode, 604
reading ease, 706
recent
in Find/Replace, 452, 455, 460
language, 684
open file, 2
Palette Dock behavior, 588
reference management, 345–346, 348–349, 352
Reference Tools, 343
reflect margins, 174
Registered Trademark, 37
Registration, vi
remove
attributes
using Statusbar tags to, 20
background color, 432
bookmarks, 307
cells, rows or columns from tables, 273
color from text, 431
contents from a cell, 296
custom Toolbar item, 620
entry from index, 336, 344
entry from table of contents, 314, 317
extra blank lines, 472, 482
from selection, 53
Glossary entry, 585
highlight color, 431
hyperlink, 646
in Document Manager
file, 100
group, 100
search criteria, 93
in Styles
attributes from, 148
from document, 152
from text, 150, 152
index from document, 338
macro from menu, 630
page breaks, 472, 481
page guides, 591
palettes, 622
section divider, 189
selected text, 55
style attributes from text, 428
tab indicator, 135
table from document, 296
table of contents from document, 317
trailing spaces, 482
replace
Find/Replace. See: Find/Replace
spelling, 386, 390
Return character, 470–471
and section break, 189
in Find/Replace
PowerFind, 468–472, 474
PowerFind Pro, 482–483
invisible, 589
sort paragraphs, 428
Reverse, style from Classic, 718
Rial, 37
right
alignment, 30, 121, 689
tables, 268, 270
expansion, 280
gutter controlled in columns, 176
indent marker, 116–117
no "margin" in Draft View & Full Screen view, 112
tab, 130
tables
add column to, 273
lines, 289
row header, 286
right to left, 40, 46
direction marker invisible character, 589
enter text, 44, 46–48
mix with left to right, 46–47
invisible characters, 589
line wraps and indent dialog, 120
paragraph invisible character, 589
Paragraph palette, 30
ruler, 46
tab invisible character, 589
tables, 48, 267
Romanic
.rtf, 1, 608, 658
.rtfd, 1
ruler
display with different formats selected, 135
indents, 112
line wraps, 116
measurement unit displayed, 588, 678
paste, 662
right to left, 46
Ruler Tag on the Statusbar, 20
show/hide, 678
structure paragraphs, 112
tabs, 129, 132, 135
Rupee, 37
Russian
S
sandbox, 632, 707
save
as
macro, 630
PDF, 562
PostScript, 563
automatic, 601
automatically, 4, 74
without Save As dialog, 601
drafts, 74
export as, 76
Find/Replace expressions, 454–455
first time, 3
formats, 74
indicators on
Title Bar, 10
meta-data saved with file, 548, 606
methods, 599
preferences, 609
templates, 167, 586
screen, 220, 435, 437
scripts
in Find/Replace, 466
section, 256
break in Find/Replace, 471–472, 481
break, invisible character, 589
header/footer (first page special) per, 184
insert
new, 256
number of, 671
number of pages per, 671
section break, 670
mirror margins for, 174
number in headers/footers, 182
numbering, 256
Page Setup per, 170
restart numbering for, 189
restart numbering pages for, 188
Section (#) palette, 174
location of, 26
set margins manually for, 174
set margins numerically for, 172–173
x as an aspect of
columns, 175
footnotes/endnotes, 259
header/footer, 184, 186
line numbers, 411–412
margins, 171
paper size, 167
Section Mark, 37
select. See: invert selection
everything, 51
multipart, 51
next/previous shape, 239
rectangularly, 51
remove from selection, 53
shapes, 238
text, 51
text, all in document, 51
using the keyboard, 51
selection
column, 51
mixed
display, 137, 486, 574
multipart, 51
next, 379
previous, 378
rectangular, 51
send to back
shapes, 238
sentence
in Find/Replace
end of sentence position, 469
start of sentence position, 469
triple-click mouse to select, 51
serosseugi, 229
settings, 567
Shadow, 29, 138
shadow, 686
of shapes, 243
Shape Fill palette, 242
Shape Metrics palette, 244
Shape Shadow palette, 243
shapes, 195, 197, 224, 236
add to document, 236
adding, 224
adding captions to, 233
anchor, 211
bounding box, 213
bring to front, 238
Canvas, 247
canvas
paste spot, 247
copy appearance of, 250
deleting, 207
duplicate, 250
fill, 242
general rules, 225
group, 238, 241
kinds of, 224
modify, 237
move precisely, 244
multiple selected, 241
opacity, 242
palette, 224
paste appearance of, 250
resize precisely, 245
rotate, 246
select next, 239
selection mode, 238
send to back, 238
set preferred appearance of, 249
shadow, 243
shadow of, 243
text wrap, 216
text wrap around, 218
ungroup, 238, 241
Sheqel, 37
Simplified Chinese
slash (/) in To Capitalized, 440
smart quote, 37, 440, 582
soft hyphen, 37
sort
paragraphs, 428
source records, 549
Spaces
insert various, 37
spacing, 124
Special Characters, 38
spelling, 384–386, 388–391, 394
alternate dictionaries, 394
attribute of Nisus New File, 592
check as you type, 385, 592
Commands explained, 667
correct using
keyboard, 385
mouse, 386–387
activate, 389
add word to dictionary, 390
find next error, 390
replace misspelled word, 390
skip all, 390
skip flagged word, 390
start point, 389
stop checking, 390
Language palette for, 25, 43, 384
thesaurus, 385
preferences, 385
QuickFix autocorrect, 385
selection highlight color, 576
user dictionaries, 391
edit, 391
Spotlight, 92
stale, 190
stationery, 1, 586
Statusbar
Background Color Tag, 432
Clipboard menu, 53, 56
Copy, 53–56
edit, 56
Color Tag, 431
edit styles, 143
Highlight Tag, 431
Language Tag on, 43, 47
Notes Tag, 257, 262–264
Styles Tag, 137, 150, 152
stepper
illustrated, 29
style libraries, location of, 567
style library, 154, 157, 159, 164–165
style sheet, 136
Style Sheet view
as default view of document, 587
styles, 136–139, 143–145, 147–148, 150, 152–153
add or modify attributes for, 148
and the Dropper, 111
apply to text, 137
assign keyboard shortcut to, 147
attributes overridden, 137
change name of, 145
control overall appearance of file with, 3, 136
copy & paste text with, 57
create new, 148
determine style of next paragraph, 147
find text using styles, 150
format index, 339–340
format table of contents, 317–319
multiple various, 319
in Find/Replace. See: Find/Replace:attribute sensitive
index as an attribute of, 333
languages, 394
QuickFix as attribute of, 581
leader tab, 132
lists
auto incrementing, 66–67, 115
modify, 144
Normal, 138
of tables, 267
lines, 289
shading, 292
remove attributes from, 148
remove from document, 152
resolve conflicts between, 153, 569
search text using styles, 150
select
all text with, 150
next text with, 150, 263
special "styles", 428, 431–432, 686–687
Style Sheet defined, 136
Style Sheet view, 143
table of contents as an attribute of, 314
text attributes, 707
various kinds supported, 138
Super B (paper size), 168
Swung Dash, 37
sync settings, 567
synchronized settings, 567
Syriac, 49
system
requirements, i
T
Table of Authorities, 341
table of contents, 313, 315–316, 319–322
commands explained, 696
create new, 319
designate text for, 313, 320
display in Navigator, 313
format, 318–320
highlight
text in, 314
insert into document, 315
jump to heading, 314
jumping to text, 321
remove entry from, 314
remove from document, 317
search, 314, 321
see text included in, 313
Table of Contents palette, location of, 26
update, 316
use styles to apply, 314
tables, 265, 267–273, 276–278, 281–285, 288–289, 291–292, 294–296, 436
add cells to, 272
adjust cell padding, 286
alignment, 270
of text in, 270
along decimal point, 271
Borders palette, location of, 26
cells
add, 272
lines, edges, borders, 288
merge, 274
navigate among, 269
padding, 286
remove, 273
select, 269
shading, color, 292, 294–295
split, 277
Commands explained, 692–693
create, 266
from pre-existing text, 268
headers, 285
row header, 286
titles, 285
cut, copy and paste, 296
determine size of new, 266–267
enter graphics in, 268
enter text in, 268
equalize
column widths, 281
row heights, 282
Find/Replace in, 296
insert, 266
Insert Table sheet, 266
color, 291
determine which, 288–289
style, 289
thickness, 291
merge cells, 274
palettes, location of, 26
remove, 296
cells from, 273
resize
cells, 278, 280
to fill page, 284
to fit contents, 283
right to left, 48, 267
select cells of, 269
Shading palette, location of, 26
split cells, 277
Table button, 266
Table Cells palette, location of, 26
Table palette, location of, 26
Tabloid (paper size), 168
tabs, 129, 132, 135
leader, 132–133
tategaki, 229
tategumi, 229
template document, 549
templates, 1, 586
templates, location of, 567
text and callout box, 228
add captions to images, 233
adding caption to, 233
adding to the document, 226
enter text, 227
expand button, 225
link button, 225
linking boxes, 231
text and callout boxes, 225
general rules, 225
text box. See: text and callout boxes
text caret. See: insertion point
text encoding, 707
Thai
thesaurus, 391, 393
Nisus Thesaurus, 392
Thin Space, 37
title page
exclude header, 184
Tok Pisin, 49
Toolbar, 14
Toolbars, location of, 567
top
alignment
text in tables, 270
margin, 173
tables
lines, 289
text drawn on images, 214
Touch Bar items, location of, 567
track changes, 521, 527–529, 531, 539, 541–542, 606
accept, 539
accept or reject, 539
copy & paste, 528
determine kinds of changes to track, 531
hide & show highlighted changes in text, 529
hide & show sidebar, 529
introduction, 361, 521
of particular author, 531
reject, 540
review changes by paragraph, 541
review changes by sentence, 541
review changes options, 541
start, 526
stop, 528
view & review, 528
trackpad
using the, 13
using the
trackpad
trackpad
trackpad, x, 7, 9, 13, 51, 53–57, 85, 88, 100, 112, 116, 135, 214, 261–262, 267, 269, 296, 379, 386–387, 505, 578, 631–632, 645–646, 669
Trademark, 37
Traditional Chinese
Turkish
typewriter, 35
U
Underline
Commands explained, 687
leader tab, 132
index, 340
table of contents, 319
using the Character palette, 29
ungroup
shapes, 238
Unicode, 40, 440, 477, 480–481, 483, 589, 663, 666, 686, 705, 708–709, 716, 718
searching for Private Use Area characters, 471
units
measurement, 119, 135, 244, 250, 588, 606, 678
Universal Resource Locator, 644
update
automatic bookmarked text, 305
automatic content, 407
Check for Updates…, 658
options on rebuilding a table of contents, 316
stale automatic content, 190
table of contents illustrated, 321
UPPERCASE
display as, 686
Urdu, typing right to left text, 44
US Legal (paper size), 168
US Letter (paper size), 168
V
view
change using the Toolbar, 14
customize, 574
displayed (or not) in various
columns, 175
headers/footers, 181, 185
images, 207, 225
line numbers, 411
page breaks, 425
section numbers, 256
Draft View, 424
Full Screen, 424
magnify, 374
new file preferences, 587
Page View, set margins in, 171
Style Sheet options, 143–144, 147–148, 152
W
watermark, 560–562
white space characters. See: invisibles
widow, 32, 128, 689
windows
aspects saved with file, 606
Clipboard, 56
close, 547
determining active, 548
expand to full size, 547
in macros, 639
minimize, 547
redisplay minimized, 547
tour of, 8, 11, 13–14, 17, 20
Untitled, 586
Window menu
using, 547
working with multiple, 11, 547
Won, 37
word
count, 400
in Find/Replace
end of word position, 469
start of word position, 468
WordPerfect, 1
dictionaries, 394
right to left
direction markers, 670
WYSIWYG, 107, 140, 142, 571, 685, 708
Y
Yen, 37
Yiddish
typing unusual characters, 715
yokogaki, 229
yokogumi, 229
Z
Zero Width Joiner, 37
Zero Width Non-Joiner, 37
zongpai, 229
zoom, 374
Commands explained, 677
Page Zoom palette
location of, 26
percentage saved with file, 548
ע
עברית, 47
가
가로쓰기, 229
세
세로쓰기, 229
종
종서, 229
횡
횡서, 229
い
印刷, 334
そ
縱排, 229
纵排, 229
た
縦書き, 229
縦組み, 229
へ
橫書, 229
橫排, 229
よ
横書き, 229
横組み, 229
横排, 229
Indexes
Commands & Screen Messages
