Move to and from comments
When you are in any particular comment, you do not need to pick up the mouse or move to the trackpad and click back into the document
► Press ⎋ to return to the body of your document, selecting the commented text.
► Choose the menu command: Tools > Comments > Go to Marked Text to return to the body of your document, selecting the commented text.
► Chose the menu command: Tools > Comments > Go to Comment Text to move from the body of your document to the comment.
► Press ⌃ or “right click” your mouse or “secondary click” your trackpad on commented text to select its comment, or the reverse to switch from a comment to its associated text in the document.
☞ The commands Go to Marked Text and Go to Comment Text toggle.
Copy and paste commented text
Select the next or previous comment in your document
