Copy and paste commented text
☞ Beware.
You can copy and paste text with its comments.
When you copy text in one document that has comments associated with it, even if the comments are hidden and you cannot see them, you copy those comments as well.
If you paste the copied text into a document Nisus Writer Pro concatenates all the text.
If you paste the commented text into a new document those hidden comments will remain hidden until you (or someone else) chooses the menu command: Tools > Comments > Show Comments.
Remove comments
Move to and from comments
