Work with Menu Commands
To use a menu command in a macro, simply type its name on a separate line. For example, these 3 commands collected into a single macro will change all text in a document to bold Lucida Grande:
Select All
Lucida Grande
Bold
• All menu commands are case insensitive.
• Menu commands with unique names can be used just as they appear on the menus.
• To disambiguate menu names, you can use the full menu path with colon separators:
Format:Underline:Single
must be distinguished from:
Format:Strikethrough:Single
All the standard menu commands of Nisus Writer Pro function exactly the same as they do if you had chosen them from the menu using the mouse or trackpad or a keyboard shortcut and require no further explanation.
Type Menu Commands
Included macros
