You can undo the effects of any macro, even the most complicated one, with a single Undo. Nisus Writer Pro combines all the actions of a macro into a single Undo command. However, undoing a macro won’t undo operations that are not undoable elsewhere in Nisus Writer Pro, such as closing or saving a file.
Previous Chapter Delete Macros |
<< index >> |
Next Chapter Work with Macro Files |
