Remove a macro file from the menu
► Use the Finder to move the file to another location on your Hard Drive.
This removes the macro’s name from the Macro menu. You can restore it (to the menu) by opening or loading it as explained above.
► Use the Finder to delete the macro file the same way you would delete any other file.
This removes the macro’s name from the Macro menu, and removes the file from your computer and it will no longer be available.
| Previous Chapter Save a Macro |
<< index >> |
Next Chapter Undo a Macro |
