Nisus Writer Pro saves each macro in its own macro file. If you change a macro file and do not explicitly save it, Nisus Writer Pro saves the file the same as any other file when you close it or quit the program.
| Previous Chapter Edit Macros |
<< index >> |
Next Chapter Delete Macros |
