Edit Macros
You edit macros just as you edit any other kind of text in Nisus Writer Pro. In fact, you can think of macros as no more than a “to do” written list of instructions that you want Nisus Writer Pro to perform.
As a shortcut, you can press ⌘ as you choose a particular macro from the Macro menu to open the macro file for editing (rather than running) the macro.
Edit a macro
1. Open the macro you want to edit by pressing ⌘ and choosing its name from the Macro menu.
2. Make any desired changes.
Rename a macro
► Use the Finder to rename the file the same way you would rename any other file.
The easiest way to find your Macros in the Finder is to choose the menu command: Macro > Show Macros Folder in Finder.
Adding macros
Save a Macro
