Edit an HTML Document in Nisus Writer Pro
Ordinarily, when you double-click an HTML document your preferred Web browser opens it. If, however, you drag the HTML file onto the Nisus Writer Pro icon in the Dock, Nisus Writer Pro will open it, and display it as though it were opened in your Web browser. You can, nonetheless, edit your HTML documents in Nisus Writer Pro.
1. In Nisus Writer Pro choose the menu command: File > Open….
2. When the Open dialog appears select the file you want to open (i.e. click the file name once in the Open dialog).
3. Click Ignore Rich Text Commands in the lower portion of the Open dialog.
4. Click Open.
☞ When you edit the raw HTML code of your file you must save the file as Text so as not to embed RTF code in the file. Nisus Writer Pro automatically sets the Save appropriately.
Export Your Nisus Writer Pro Documents to Share on the Web
Handling Communications
