Cutting Text
Cut text
1. Select the desired text.
2. Either…
► choose the menu command: Edit > Cut
► from the Clipboard tag on the Status Bar choose the menu command: Cut
► press ⌃ or “right click” your mouse or “secondary click” your trackpad and choose the menu command: Cut.
Nisus Writer Pro enables you to append cut selections of text to the Clipboard, if you…
2. Either…
► choose the menu command: Edit > Cut > Append Cut
► press ⌥ and from the Clipboard tag on the Status Bar choose the menu command: Append Cut
► press ⌃ or “right click” your mouse or “secondary click” your trackpad and choose the menu command: Cut > Append Cut.
…to
remove the current selection and insert it at the end of whatever is stored in the current Clipboard.
As explained in the section on Drag and Drop, you can simply drag a selection from one location to another in the current document or across documents. Because this removes your selection from one place, you must “drop” the selection into another portion of your document.
Delete text
When you choose the menu command: Edit > Cut you actually place a copy of that text on the Clipboard. However, if you just want to delete the text
► Choose the menu command: Edit > Delete to remove a selection
► Press ⌫ to remove the characters to the left of your insertion point (or the selection)
► ⌘⌫ removes everything from the insertion point to the beginning of the paragraph, but no further.
► ⌥⌫ the first full word behind the insertion point. Continue pressing ⌥⌫ to remove more text one word at a time.
Drag and Drop
Pasting Text
