Create Sections
You can separate portions of your Nisus Writer Pro document into different sections with varying locations of margins, number of columns, and numbering formats. These sections can begin on the following page, the next odd page, the next even page or even on the same page.
Insert a new section
1. Place your insertion point where you want the new section to begin.
2. Choose
► the menu command: Insert > Section Break > Next Page to have the section begin on the following page, whether it is odd or even.
► the menu command: Insert > Section Break > Odd Page to have the section begin on the following odd page.
► the menu command: Insert > Section Break > Even Page to have the section begin on the following even page.
► the menu command: Insert > Section Break > Same Page to have the section begin on the same page.
☞ You can now modify various aspects of the format of your new section using the palettes of the Sections group in the Palette Dock.
Book Tools
Number Sections
