Graphics: Images and Shapes
This portion of the manual shows you how to work with graphic images and shapes. The sections include
Work with Various Types of Graphics 196
Import Images 198
Resize an Image 203
Crop an Image 204
Edit images using Markup 206
Image opacity 204
Work with Floating Images 207
Delete shapes and floating images 207
Use the Shape Wrap palette 209
Make an inline image into a floating image 209
The Shape Anchor 210
The contextual menus for inline and floating images 211
The Shape Bounding Box 213
Align a floating image 214
Cause text to wrap around an image 215
Set the padding text leaves around an image 218
Cause text to appear on top of, or behind an image 219
Cause images to appear around text; create a “screen” behind text
219
Make a floating image an inline image 221
Work with Shapes 224
Insert shapes 224
Add a shape to your document 224
Use the Shapes palette 224
Text and Callout boxes 225
About Text and Callout Boxes 225
Add a text or callout box 226
Add a caption to your images 233
Draw lines and arrows 234
Geometric type shapes 236
Modify shapes 237
More tools on the Shapes palette 237
Select floating shapes without selecting text 239
Rearrange the front to back order of various floating shapes
241
Cause selected objects to function as a single unit 241
Cause grouped objects to function as a individual items 241
Work with multiple selected shapes 241
Use the Shape Fill palette 242
Use the Shape Shadow palette 243
Use the Shape Metrics palette 244
Move selected shapes by precise, designated amounts 245
Resize selected shapes by precise, designated amounts 245
Rotate selected shapes 246
The Canvas 247
Working with a Canvas 247
Additional tools for working with shapes 249
Set a preferred appearance for future drawn shapes 249
Copy the appearance of one shape to apply to a different shape
250
Duplicate shapes 250
Number Pages
