Integrate AppleScript with Nisus Writer Pro
The argument of the Do Menu Macro can be any Nisus Writer Pro menu command (even the name of a macro, style, etc.). In addition, you can put almost any Nisus Writer Pro macro programming dialect command in an argument. A few examples follow.
Write AppleScripts for use in Nisus Writer Pro
1. Write AppleScripts in Script Editor.
☞ You can find the Script Editor in the AppleScripts folder of the Applications folder.
Applications/AppleScripts/Script Editor
2. Save your AppleScripts as compiled scripts (with a “.scpt” extension) or plain text (with a “.applescript” extension) in the folder
~/Library/Application Support/Nisus Writer/Macros
Have AppleScripts open a new file
► tell application "Nisus Writer Pro"
Make at front of documents new document
end tell
Have AppleScript open a file and perform some tasks
This script tells Nisus Writer Pro to open a new file and type “Hello World.” It then selects all the text, applies the font Times New Roman, then makes it Bold and Red.
► tell application Nisus Writer Pro
Activate
Set newDoc to make at front of documents new document
Set text of newDoc to "Hello World."
Do Menu Macro with macro "Select All"
Do Menu Macro with macro "Format:Font:Times New Roman"
Do Menu Macro with macro "Format:Bold"
Set
color of text of newDoc to "red"
end tell
See a list of all the AppleScripts commands that Nisus Writer Pro recognizes
► Drop the Nisus Writer Pro application icon on the Script Editor application icon.
Plain text AppleScripts have an extension of 'applescript' and compiled scripts have 'scpt'
The two most useful commands supported Nisus Writer Pro are:
• getting and setting the text of a document
• running Nisus Writer Pro menu macros.
Get/set text
You can get the main body text of any open document, or any character, word or paragraph of that text. You can also set the entire body text or any portion of it. You can also get or set the text color of any piece of the text.
Examples
• tell application "Nisus Writer Pro"
 get text of document 1
end tell
 get character 3 of word 1 of paragraph 1 of text of document 1
end tell
  set word 1 of text of document 1 to "Modified Text"
end tell
  set color of words 1 through 4 of text of document 1 to "green"
end tell
Nisus Writer Pro has a limitation when setting the text in that the changes caused by the AppleScript are not undoable and may cause problems with existing Undo/Redo actions.
Do Menu Macro
You can run any string of text as a Nisus Menu Macro
Examples
• set macroString to "Format:Size:Increase" & return & "Format:Font:Apple Chancery"
   activate
   Do Menu Macro with macro "Edit:Select All"
   Do Menu Macro with macro macroString
end tell
Other examples
• This script will insert the path to the front document at the end of the document
if exists (path of document 1) then
   set thePath to path of document 1
else
   set thePath to "No Path"
end if
make new paragraph at end of text of document 1 with data (return & thePath)
end tell
Write AppleScripts
Put It All Together
