Use Comments
A quick intro to comments 497
The Comments Interface 498
The Comments commands on the Tools menu 498
Comments tools on the Toolbar 499
The Comments Sidebar 499
The Comment windoid 503
The Comment icon in the margin 504
Comment related tags on the Status Bar 505
Remove comments 505
Copy and paste commented text 505
Move to and from comments 505
Select the next or previous comment in your document 505
Collapse or expand the comments in your document 506
Hide and show, or turn off and on the display of all the comments 506
Receiving commented files from others 517
Add your comments to the comments of others 518
Review threaded comment conversations 518
Display comments of a particular “author” 519
Create your own Comment style for your Nisus New File 519
Select text and count words in all comments 519
Export comments 519
Use comments as a “hidden text” feature 520
Nisus Writer Pro enables you to add comments to your document. When you share these documents with others, they can read your comments and/or add their own. Comments can be shown whenever you are in Draft View, Page View or Full Screen view but not in Style Sheet view.
You can print your documents with the comments visible so you can read all the comments on paper (or in a PDF version of your file). You can export your comments to a new document. With this capability you can maintain a timely journal then collect your thoughts in a new document for use elsewhere.
☞ Some features of Comments apply equally as well to the use of Tracked Changes (explained in the section: “Track Changes“ beginning on page 521). When discussing them both, the terms ”annotations” and/or “ancillary content” are used.
Use the Formatting Examiner
