Macros, an Introduction
Macros automate repetitive tasks and combine in one “command name,” a whole collection of tasks you frequently perform.
It is easy to combine the menu commands of Nisus Writer Pro into your own custom combinations. These combinations are called “Macros”. Consider each menu command in Nisus Writer Pro a “micro” command. Putting them together, creates a “macro.”
This portion of the manual describes how to create, run, delete, and save simple macros.
☞ The Macro Language Reference is distributed with the application. You can open it by choosing the menu command: Help > Macro Language Reference. It details all the features of the macro language. You can learn more and explore macros created by others in the Nisus Writer Pro community at <https://nisus.com/pro/macros>.
About Macros 629
Run Macros 629
Edit Macros 630
Save a Macro 630
Delete Macros 630
Undo a Macro 630
Work with Macro Files 631
Before Creating a Macro 631
Type Menu Commands 631
Work with Menu Commands 632
Create Your Own Group of Palettes for the Palette Dock
About Macros
