Paginate, Sort and More
This portion of the manual shows you how easy it is to give your documents a polished, professional look. The sections include
Pagination 417
Alphabetize (Sort) Paragraphs 422
Special Formatting Tools 422
Plain Text 422
Remove formats from text 422
Change the height of text in relation to the baseline 422
Cause letter pairs to use ligatures 423
Cause letter pairs to display closer together or further apart 424
Color text 425
Highlight text 425
Background color 426
Use Paragraph Borders and Paragraph Shading to set off your text
428
Use the MacOS Colors panel 431
Clean Up Documents 433
Change the case of alphabetic characters 433
Change the appearance of quotation marks 433
Number lines
Pagination
