This portion of the manual contains instructions for using the tools supplied by Nisus Writer Pro to make sure you use the correct words in your documents.
Check spelling using the Language palette 384
Correct your typos as you type 385
Set your dictionary preferences 385
Correct your spelling using the keyboard and without calling up the Spelling window
385
Correct your spelling using the mouse or trackpad and without calling up the Spelling window 386
Start the spelling checker 388
Set the starting point of the spelling checker 389
Activate the Spelling floating window 389
Replace a misspelled word using the spelling checker 390
Skip words flagged by the spelling checker 390
Use Multiple Language Dictionaries 394
Alternative spelling checker dictionaries 394
Word counts & text statistics 400
| Previous Chapter Jump to a particular page |
<< index >> |
Next Chapter Check Spelling |
