"Space" between bottom of page/paragraph
Jester
Post by Jester »
Hi!
Sometimes (not always) Nisus leaves a blank space at the bottom of the page when a paragraph does not end in said page, I've attached a file so you can see what I mean. Is there any way to correct this? I got some points off in my previous thesis because of that hehe. I've highlighted the part in which I believe there shouldn't be a space below it.
Thanks!
Sample nisus.rtf
(29.34 KiB) Downloaded 458 times
Kino
Re: "Space" between bottom of page/paragraph
Post by Kino »
Dunno how it is called in Spanish but switch to Style Sheet view, select Normal 1 (everything in your document is in this paragraph style) and uncheck Format:Paragraph Layout Options:Disallow Widows & Orphans. If you use always Normal 1, I think you’d better correct it in Nisus New File.dot (Preferences => New File => Advanced and Edit Nisus New File...).
Jester
Post by Jester »
^ As far as I know Nisus is only available in English. Thanks for the quick reply!
OK let's see…, great, seems to work, thank you very, very much!
Nisus is available in seven different languages:
Danish
English
French
German
Italian
Polish
Spanish
