Is the menu item "Open macro folder" itself a macro?
Is it possible to write a macro that opens any given folder?
Re: menu item "Open macro folder"
That particular menu isn't a macro, but you can easily replicate its effect with any folder you like:
File.revealPathInFinder('~/Documents')Re: menu item "Open macro folder"
Thank you Martin. I hope someday we will get a book or a file to teach the less talented among us some of these more basic things one can do with the Nisus macro language. Or is there one already?
As to the macro itself I still would need some fine tuning to get what I want. The first problem is: Your sample macro shows the documents folder within the next higher level which is opened. But I would want the macro to open the documents folder itself.
The second problem is: I wanted to open a folder with a two word name (within another folder with another two word name). I thought I could copy the path I get by pulling the folder onto the terminal window and copy it from there. This did not work. I tried to outquote the space character with backslashes, but maybe I did not do it properly. How should one proceed with special characters in the file name to make the macro work?
Addendum:
I take my first question back: When I changed the filename, deleting an empty space. Now the macro worked, as expected. Strange as it may sound, when I put put the space back again, it worked also, with the space. No idea why. What I learned in the process is, that Nisus can handle spaces without the backlashes added, if you pull a file icon onto the terminal. In fact you have to take them out again to work in Nisus.
As to opening a older rather than only showing it's name in the higher level folder I realize that this can be solved by adding an empty dummy folder together with the files and calling that instead ...
Thanks for your help anyway.
The best we have is the Nisus Macro Reference, which is included in every NWP download, or can be obtained separately from the macro repository. It's been often commented that the document is terse and could use more examples and do a better job of teaching, so I don't know how much it would help someone in your position. It does however at least detail every command available, which is the primary intent of the guide.js wrote:Thank you Martin. I hope someday we will get a book or a file to teach the less talented among us some of these more basic things one can do with the Nisus macro language. Or is there one already?
That's exactly right, the strings/paths in NWP don't require any special escaping/backslashes. For a full list of special characters that require escaping see the "Literals" section in the Macro Reference.When I changed the filename, deleting an empty space. Now the macro worked, as expected. Strange as it may sound, when I put put the space back again, it worked also, with the space. No idea why. What I learned in the process is, that Nisus can handle spaces without the backlashes added, if you pull a file icon onto the terminal. In fact you have to take them out again to work in Nisus.
I'm glad you discovered a work around- it's the best you can do I think. The "reveal" command just tells the Finder to do the showing, so we're really at the mercy of whatever Apple decided is best for showing the requested file/folder. In my own experience the Finder's decisions aren't always that great.As to opening a older rather than only showing it's name in the higher level folder I realize that this can be solved by adding an empty dummy folder together with the files and calling that instead ..
Nobumi Iyanaga
Hello js,
I think the simplest in such a situation is to use the Terminal command "open", via Perl block. An example:
The Terminal command in a Perl block must be enclosed between two "`" ("grave accent" or "backticks"); and it is better to enclose the file path between double quotes.
I hope this helps.
Begin Perl
`open "/Volumes/myVolume/myDocument/temp/Eudora Pro 4.2-J/"`;
EndI hope this helps.
Best regards,
Nobumi Iyanaga
Tokyo,
Japan
Nobumi Iyanaga
Tokyo,
Japan
