Is there an easy way to search/find any characters in a large document which are Hebrew?
Search/find any Hebrew characters
Re: Search/find any Hebrew characters
G'day, rabbijacobs et al
Insert the following expression (without quotation marks) in the "Find what" field of the Find & Replace window using PowerFind Pro: "[\u0590-\u05FF]"
Another easy way is to use AnyHebrew from the Scripts/Blocks menu.
You can also use "\p{Hebrew}" (without quotation marks) if you are comfortable with PowerFind Pro.
- 1.png (196.07 KiB) Viewed 5307 times
