dir="ltr" style="text-align:justify;margin-bottom:0.0833in;margin-top:0.0000in;margin-right:0.0000in;text-indent:0.1944in"Has anyone here had good luck using NWX to produce simplified HTML? Is there a good way to remove formatting in an NWX document before exporting it that would result in a simpler HTML export? All I'm really looking for is the most generic meta-level formatting: Bold/Italic/Underline, Super/Subscript, simple table, and a few structural formatting elements like lists and BLOCKQUOTE (and heading levels if possible).
(The basic idea here is taking various RTF documents and putting them on handheld readers like Palm and PocketPC; complex formatting usually isn't supported on those readers, takes up extra storage space, and can occasionally cause ugly compatibility issues.)
Thanks for any replies!
