After upgrading to the latest version (2.1) NWE has got very unstable, crashing 50% of the time when opening a new document.
Am I the only one experiencing this? I don't think it's a corrupt file or such like as it can happen with any document. Is it recommended to trash the NWE prefs, and if so, which ones?
Thanks for any feedback.
Trash prefs?
- GeoffRoynon
Trash prefs?
I am also having crashing problems in 2.1 but not as often as 50% - more like 20%.
I have reported this to Nisus but have no idea what is causing it. If I do find a cause or a fix I will report back.
Geoff
Geoff
Geoff Roynon
Mac Studio, MacOS X 14.0 Sonoma
NW Pro 3.3
NW Pro 3.3
Hi:
Just to let you know that we have found a crasher bug introduced in 2.1 that happens especially after you open and close a document quickly (before the background spell checker has time to finish checking the document.) We are working on a fix right now and we will make it available to you ASAP.
-Charles
-Charles
Charles Jolley
Nisus Software, Inc.
Yesterday I had a NWE document that crashed Spell Catcher all the time. As soon as I tried to do anything in NWE, it crashed Spell Catcher and Spell Catcher restarted itself all the time and after some minutes I decided I had enough of it. I had to restart the computer to be able to work with NWE and Spell Catcher.
Today it has been working without any problems, but I have not been working as much as I did yesterday.
/Peter
/Peter
Peter Edwardsson
MacBook Pro M1 | macOS Sequoia
Yeah, it seems to be a »jumpin’ bug».charles wrote:Peter:
This bug we are working on may or may not be the cause of the problems you experienced with Spell Catcher. This one is tricky because it is timing related which means it can appear to jump around on you. (Even though that is not really the case.)
-Charles
Hope you get rid of it asap, just can’t stand »jumpin’ bugs»…
Peter Edwardsson
