Unable to set up table properly
GeoffRoynon
Post by GeoffRoynon »
I am using NWE 2.1 and was playing around with the table tool today. What I want to do it create a table with 9 columns and 12 rows but I want columns 1, 3, 5, 7, and 9 to be the same size (e.g. 3cm) and columns 2, 4, 6, and 8 to be a different size (e.g. 0.5cm). It appears the only way to do this is by manually dragging the cell delimeters which makes getting the cells to match almost impossible.
I have read the manual but it didn't appear to have any hints about how to do this. Is this possible?
Geoff
Geoff Roynon
Mac Studio, MacOS X 14.0 Sonoma
NW Pro 3.3
Sorry Geoff, but at this time there is no way to exactly specify table column sizes, you just have to "eyeball it". Also, while you can automatically equalize the width of adjacent columns, you will not be able to equalize columns that are not neighbors.
