Express 2.0.1 unstable ?
pdumais
Post by pdumais »
Hi, I just upgraded to 2.0.1 and I find it unstable. Three times out of four, the program unexpectedly quits while trying to open a .rtf file (same happens regardless of what file). It also quit unexpectedly when I did CMD-N (I was aiming for CMD-B).
I'm running OS 10.2 on a 333 MHz G3 (iMac) w/ 384 M memory.
JBL
Post by JBL »
I am sorry to hear about your problems. NWE has been very stable for me. I think 2.0 crashed on me once or twice but I have been using 2.0.1 every day since it came out and never had it crash. Running 10.3.4 and 10.3.5 on a G5 and a dual 1.42Ghz G4.
joao
Post by joao »
I've had some consistent crashing problems with table shading, but other than that I've found the program quite stable, and the command-N combination (which I use a lot) hasn't given me any problems.
I'd suggest that you send feedback about the crash from within the program, as I believe a crash log is sent along with the feedback - which is useful for diagnosing the problem.
pdumais
crash log
Post by pdumais »
where would I find the crash log ?
MacSailor
Re: crash log
Post by MacSailor »
pdumais wrote:where would I find the crash log ?
Usually at /Users/username/Library/Logs/CrashReporter
or at /Library/Logs/CrashReporter
/Peter
Peter Edwardsson
cchapin
Post by cchapin »
As I understand it, the feedback mechanism collects that information automatically. All you need to do is (1) cause a crash, (2) restart NWE and (3) click the Help menu, then Send Feedback. Type in a brief explanation of the problem and send it off.
The folks at Nisus don't guarantee a response to feedback sent this way, but it is the best way to get system-specific information to them for problem-solving.
--Craig
