Statistics Palette
Les
Statistics Palette
Post by Les »
Using Mac OS 10.14.1 and Nisus Writer Express 3.5.10, the Statistics Palette indicates Character count and Paragraph count, but does NOT indicate Word count. This issue is the same when the document is highlighted, and also on documents created with older versions of Nisus Writer Express. Anyone having this issue?
Re: Statistics Palette
Hi Les: we already solved this problem privately when you contacted us via email, but I wanted to post a solution here too. Just in case anyone else experiences this issue.
The problem was that the "count words" option was turned off in Nisus Writer's language preferences. This option needs to be checkmarked for all relevant languages (all languages used in your documents).
