Erratic mouse behaviour over tables
ianpiper
Post by ianpiper »
I'm using v2.1.8 and having a problem with the mouse. I have a number of tables in the document and when the mouse pointer moves over the table cells it becomes jumpy and erratic; it's almost like the brakes go on. Once outside the table the mouse pointer moves as normal. Very strange behaviour. Is this a known problem, and if so is there a known fix for it?
This is on a MacBook Pro (Retina, mid 2015) running Sierra 10.12.6. I'm using an Apple Magic Mouse, but the behaviour is the same with the trackpad.
Thanks for any guidance.
Ian.
Vanceone
Re: Erratic mouse behaviour over tables
Post by Vanceone »
That sounds interesting.
The only thing I can think of is if you've got a bunch of embedded stuff in the table; in particular images; and Nisus is trying to put up various overlays of data.
Does it do it on a new document table that only contains text in the cells? Also, are there links or captions?
