Overbar
quiggin
Overbar
Post by quiggin »
Is there any way of adding an overbar to a character (I want p) in current versions of Nisus. I recall it used to be feasible and Google produces hits from the 1990s supporting this, but all the recent discussions Iʻve seen are unhelpful. I donʻt know why such a basic feature isnʻt supported in Unicode (if it isnʻt)/
Re: Overbar
quiggin wrote: ↑2018-07-04 22:49:36 Is there any way of adding an overbar to a character (I want p)
Do you mean something like this: ֿp
Elbrecht
Re: Overbar
Post by Elbrecht »
Hi quiggin –
what language/transliteration is p̄ for? You can compose characters, you have no pre-composed ones available for, on the wild via "U. S. Extended" keyboard. Therewith enter your "character" first followed by "SHIFT/OPTION:A" for a macron thereon. For other options inspect "Show Keyboard Viewer" while in "U. S. Extended" keyboard.
Enjoy
HE
MacBook Pro i9
Tahoe 26.7
NWP 3.4.1
quiggin
Re: Overbar
Post by quiggin »
@ Þorvarður
Thatʻs exactly what I want
quiggin
Re: Overbar
Post by quiggin »
@Elbrecht Thanks, that works fine. I'm in Australia so I used ABC Extended rather than US Extended which is not available on my Mac.
Elbrecht
Re: Overbar
Post by Elbrecht »
Hi quiggin –
you are right: "U. S. Extended" is now with newer MacOS called "ABC Extended" – I happened to post from Mavericks!
HE
MacBook Pro i9
Tahoe 26.7
NWP 3.4.1
