Text Skips a Page and Leaves it Blank
Wizardiaoan
Post by Wizardiaoan »
I do love Nisus but have a problem in one document I can't figure out.
When writing text as it gets to the bottom of the page the text will skip the next page and continue writing on the page after that.
This doesn't occur every time like some "write on every other page" setting, but only now and then throughout the document in a few cases.
To solve the problem I just started a new document and copied everything to it and it worked. I was just wondering what the problem could have been?
Re: Text Skips a Page and Leaves it Blank
Hello Wizardiaoan,
Wizardiaoan wrote:I was just wondering what the problem could have been?
Are you sure you haven't accidentally inserted Page/Section Breaks into your document?
Enable "Show Invisibles" and search with the wild card "Any Break."
Any unruly shapes floating around?
If you have pasted text from the Internet or from other programs, it may contain invisible characters that may or may not affect how the text flows. Often these gremlins can be seen if the "Show Invisibles" is enabled. — Here is a macro that removes this invisible junk.
Remove Gremlins.nwm.zip
(4.01 KiB) Downloaded 503 times
Wizardiaoan
Thanks sir.
What did you mean by "search with the wild card 'any break'"? How would I do that?
Thanks.
Wizardiaoan wrote: What did you mean by "search with the wild card 'any break'"? How would I do that?
