I have trouble importing EPS graphics, what's going on?
Moderator: faq-editor
Certain graphics programs (including some music notation applications) do not properly specify the "bounding box" that is used to relate the size of the graphic to the PICT preview that is displayed on-screen. Luckily, there is a shareware program called <i>EPS Fixer</i> that will correct this problem in your EPS files. Simply download <A HREF="http://wuarchive.wustl.edu/systems/mac/ ... t.hqx">EPS Fixer 1.5.2</A> and follow the instructions.
