In 5.1.3 my footnotes and their numbering got screwed up.
Moderator: faq-editor
There is a footnote bug in version 5.1.3 of Nisus Writer. In the footnote window, the user is allowed to delete across footnotes. This had never been allowed before, and can make the automatic numbering system go nuts when this happens, because it thinks the two footnotes have merged, while there are still two references. As long as you try not to delete across footnotes, everything should be fine. The best solution is to upgrade to <A HRef="http://www.nisus.com/Express/">Version 6.0</A> where the bug has been fixed.
