Table question
lyndondrake
Table question
Post by lyndondrake »
(BTW, thanks for Nisus: I'm beginning to really love it, and appreciate all the work that has gone into it.)
When I create a new table, the first row of the table ends up with some space above it. As an example, here's a new document with two columns to demo:
https://www.dropbox.com/s/h0zhx2m45qs4v ... 4.png?dl=0
My guess is that it's something to do with my template and formatting, rather than a flaw in the tables engine. But I can't figure out what I should change to make the top rows align with each other.
Lyndon
Re: Table question
You can adjust the vertical (and horizontal) displacement of a table as follows:
  • "Select" the table so that the little blue corners appear
  • Hover the cursor over the desired edge of the table—top for vertical, left for horizontal
  • When the "hand" cursor appears, click and drag the table to the desired location
I think Nisus inserts tables with a slight amount of vertical displacement (down), which becomes noticeable in your case since the second column is a continuation of a single table, and therefore Nisus "jams" it all the way up to the margin.
lyndondrake
Re: Table question
Excellent, that worked. Thank you!
