Yes, you can store your Nisus Writer word processing documents on iCloud. Here's how:
1. Make sure that you are using a recent version of Mac OS X. You may use Mac OS X 10.10 (Yosemite) or Mac OS X 10.11 (El Capitan).
2. Make sure that you have iCloud Drive enabled in your system preferences. If you need help with that, please follow Apple's instructions on how to enable iCloud Drive.
Once you have iCloud Drive enabled on your Mac, you will see iCloud listed in every Nisus Writer file dialog. Any documents saved to iCloud Drive will be automatically synchronized and made available on all computers using the same iCloud account.
Does Nisus Writer Express work with iCloud?
Moderator: faq-editor
dave
- save.png (31.11 KiB) Viewed 139058 times
