Can anyone provide a Macro to change
endnotes (and in-text references) designated by superscript digits to
endnotes (and in-text references) designated by plain digits?
Many thanks, if so. JT
Macro: convert superscript digits to plain digits, endnotes.
Re: Macro: convert superscript digits to plain digits, endno
Depending on your needs, Nisus might do this for you already. When you copy text, Nisus stores multiple versions on the clipboard; if you paste it into a text editor, it will use the text-only version. For example, here are the results of a single sentence with two footnotes, copied from Nisus and pasted into iA Writer:
The same works for footnotes, which is where I noticed it a few days ago.
For the text box used for forum posts here, Safari also chooses the text version rather than the formatted version.This is1 a test of numerical endnotes.2
1. For varying definitions of is.
2. A second endnote!
Can you perhaps clarify what you'd like to see exactly? Are you just trying to change the formatting applied to your note references, or are you trying to do some kind of text conversion along the lines of what capvideo described?
Sorry for my long absence. I plan to convert RTF files to HTML for a WordPress blogging platform which I use for an issue-based magazine, appearing twice a year. I would like to be able to convert a Word document with footnotes (indicated by superscript numerals) (automatically converted to RTF by Nisus WP) to an HTML file with Endnotes indicated by [Note 1], [2], [3], [4], [5] and so on (using non-superscript numerals) both in the text and at the head of each Endnote [links take you from one to the other]. Any takers? Is there a Nisus Writer Pro macro that might automate this? Doing it manually is okay for five to ten endnotes, but any more and it becomes tedious. Many thanks, JT (Oh, an example: http://poeticsresearch.com/article/radi ... ere/#fnB12)
This macro might be what you're after JT. It converts all the footnotes and endnotes in your document to regular text, placed at the very end of your document. It also applies some bookmarks and links, so that an HTML export will let you click on the note reference to see the corresponding note's text.
Convert Notes to Linked Text.nwm
- (23.23 KiB) Downloaded 1158 times
Many thanks, Martin. I really appreciate this!
