Any way to insert attachments?
steveyum
Post by steveyum »
Is there a way to insert attachments, such as zip files? If there is a way, I can't seem to find it.
That's a feature I use a lot in Evernote, and I wonder why no word processors or even text editors have this feature.
I use Nisus a lot for documenting purposes, namely technical docs, for myself. And it would be great if I can attach any type of files, whether they're zip or just even regular text snippets as attachments.
If such feature doesn't exist, can this be added in the near future? Thanks.
S
Re: Any way to insert attachments?
steveyum wrote:Is there a way to insert attachments, such as zip files? If there is a way, I can't seem to find it.
Select the file icon in Finder, copy with Command + c, and paste into your Nisus document. That will add a hyperlink to the file.
Isn't this what you want to do?
As Þorvarður mentioned, you can link to arbitrary files on disk using Nisus Writer. However, you cannot embed attachments of any type into a document.
