Unresponsive floating text box - how to resolve?
whitetornado
Post by whitetornado »
Hello,
Since Nisus does not allow columns (right?), I am trying to put small notes in the margin by placing a number of floating text boxes (Floating Shape > Text Box).
I blurred the text because it doesn't matter. As you can see, there are three floating text boxes in the right margin. But the top two are not responding! I cannot select them, let alone edit (or delete).
They also show up when I render a PDF of the document:
But sometimes, when I scroll a bit in my document, they disappear:
Please help! I need to edit them, or at least be able to delete them!
Is there a different solution I could go for, to have little comments in the margin?
Re: Unresponsive floating text box - how to resolve?
Floating contents can go loco every now and then. For a start, try the macro that I provided here http://www.nisus.com/forum/viewtopic.php?f=17&t=5289 just to make sure that the floating contents exists properly. If the textbox is there, but doesn't show properly, consider sending the document to Nisus, and have them take a look at.
Hello– I'm sorry you've had trouble with your floating text boxes. They should always be editable / movable, even in the margin. Could you possibly share you document with us so we can have a look at what the problem might be?
whitetornado wrote:Since Nisus does not allow columns (right?)
Nisus Writer Pro (NWP) does allow columns, but only snaking columns (eg: the bottom of column one flows to the top of column two). We do not have support for parallel columns that run side-by-side.
whitetornado
Hello,
Sorry for getting back so late - didn't get an email notification of any replies and some other things got in the way of keeping a close eye on this topic. Thank you very much for both your responses! I will look into the macro and would be happy to share the document, though I'd rather not have it publicly available on the web. It is over 200kb so I cannot attach it anyway to the thread. What is your preferred method of sharing documents? Thanks again, let's hope we can find a solution!
whitetornado wrote:Sorry for getting back so late - didn't get an email notification of any replies and some other things got in the way of keeping a close eye on this topic. Thank you very much for both your responses! I will look into the macro and would be happy to share the document, though I'd rather not have it publicly available on the web. It is over 200kb so I cannot attach it anyway to the thread. What is your preferred method of sharing documents? Thanks again, let's hope we can find a solution!
No problem on the delay. Whenever you find time, please send us the document using the menu Help > Send Feedback, or email it to us directly at:
If the content of your document is sensitive, please let us know and we will destroy it after testing. Thanks for your help!
whitetornado
The macro for counting all floating content did include them in the count. I sent the document to Nisus. I hope to post a solution or workaround later.
