Writing on one page in to columns
Orientalist
Post by Orientalist »
Nisus 1.4.2
I would like to create pages with two columns on each page. It is easy, I know.
BUT: :oops: in the right columne I will write a text and in the left columne I will write an other text. I will use two spaces on the same page independently.
This in order to create a synopsis between two texts.
Any help? Thanks
Orientalist
Re: Writing on one page in to columns
This is a well known problem, and unfortunately there is no perfect solution. Consider the discussion in this thread: "Facing Columns"
Orientalist
hanks, philip.
It is a crazy case since I wrote text in to spaces on one page before, but I forgot the way....and I have not the origin document at my disposal.
Orientalist
