File Folder Labels
File Folder Labels
Re: File Folder Labels
Hi philajoe,
Welcome to the forum.
The video shows how you can create Avery labels for one address, for example your home address. It also works if you want to create, let's say, 20 different labels for 20 different folders.
In the video you can also see a script labeled "Advanced". It will allow you to enter the exact amount of labels you want.
Watch the video and tell me if this is what you have in mind.
When the video starts, please click on the arrows in the lower, right corner for best performance and full screen view.
https://copy.com/Ni87Crwm7sLgoLm6
Yes.philajoe wrote:Is there any way to print Avery labels using Nisus.
I assume you want to attach Avery labels to real folders in your office. You can use the method shown in this video. It shows how this can be done in Nisus Writer Pro, almost instantaneously.I like printed file folder labels
- Screen Shot 2015-04-25 at 15.46.33.png (12.64 KiB) Viewed 3285 times
