Is there a way to Rotate a Graphic, esp. using Mouse
lindas2013
Post by lindas2013 »
I found it in the Palette, but I want to be able to "grab" the handles and Rotate. Some programs you hold the shift key and do it. How do you do it in Nisus Pro??
Sorry if elementary question.
Re: Is there a way to Rotate a Graphic, esp. using Mouse
Nisus does not have any handles on its graphics, but you can rotate them by selecting them and using the rotate wheel in the Shape Metrics palette of the Drawing Tools drawer. You can rotate using the mouse, you just have to click on the wheel and hold. You can move away from the wheel while holding, if you want finer control of the rotation.
lindas2013
Thank you, Philip.
I did think I had to keep my mouse pointer right on that wheel! It certainly helps just positioning it further out! Who knew? I guess, you!
Thanks; it does help.
Linda
