Rename Open File
foster13
Rename Open File
Post by foster13 »
Can the name of an open file be replaced so as to rename the original file and if so, how?
Thank you!
Re: Rename Open File
If you <cmd>click on the name of the file you should be able to see the folder that contains the file. If you click on the folder it will open in the finder, where you can rename it. Nisus should immediately register this name change, when you switch back.
PS: One could easily write a macro to do this from within Nisus, but I believe this is a feature due for improvement soon.
foster13
Post by foster13 »
Thank you!
Now, with the release of NWP 2.1, you can rename an open file from the File:Rename... menu.
Hamid is right, NWP 2.1 did make this easier. You can also click the little disclosure chevron icon shown in all saved document window titlebars to bring up Apple's handy file manipulation widget:
