For my dissertation I have to merge several documents into one document. When doing this normally the footnotes for the second, third etc. files are added to those of the first document. So I get footnumbers like 799 and 1015.
My question is the following: is there any method to restart footnote numbering for each chapter of the document? I want to give every first footnote of a chapter number 1.
I hope my question is sufficiently clear and apologize if that is not the case.
Many thanks for any advice in advance!
Footnote numbering when merging documents
Re: Footnote numbering when merging documents
You could insert a Section Break after each chapter, and then do this:Axonus wrote:is there any method to restart footnote numbering for each chapter of the document? I want to give every first footnote of a chapter number 1.
1. Go to Style Sheet
2. Select Note Style "Footnote" in the left column
3. Then choose an option from the "Number Restart" pop-up menu.
You can choose between [1] Continuous, [2] Per Page and [3] Per Section
- Screen Shot 2015-01-15 at 20.16.37.png (80.24 KiB) Viewed 8339 times
I am facing a similar problem.
I want to restart the footnote # for each chapter. Problem: I have sections within each chapter. Bc I use landscape settings etc for some pages within the chapter. So if I choose "restart footnote numbering for each section," I end up having multiple footnotes no. 1 WITHIN the same chapter.
Any way around this?
You can manually manage your footnote numbering, e.g. use the menu Set Custom Note Reference for each footnote, but this is tedious and error-prone to do one at a time. You might consider creating a macro that renumbers all your footnotes automatically. You can run it once after you're done writing. Such a macro might use a particular heading style to decide where to restart note numbering.madpoli wrote: ↑2022-03-12 09:04:44I want to restart the footnote # for each chapter. Problem: I have sections within each chapter. Bc I use landscape settings etc for some pages within the chapter. So if I choose "restart footnote numbering for each section," I end up having multiple footnotes no. 1 WITHIN the same chapter.
