clip selection as plain text
This is a macro to convert selection to plain text and clip it to a dedicated clipboard. This is useful to keep .rtf cruft from messing up pasted code. I ran into this when Xcode was choking on typographers quotations marks, as an example. File attached.
clipPlain.nwm- clips selection as plain text
- (20.24 KiB) Downloaded 995 times
Re: clip selection as plain text
Thank you very much, dmorgan!
Greetings, Henry.
Greetings, Henry.
Hi there, to add to the great work that dmorgan did, I'm posting a macro that will copy the entire document as plain text to the system clipboard. It will also put in double carriage returns between paragraphs if necessary.
Thanks
Lou
Thanks
Lou
Copy-as-Plain-Text.nwm- (9.36 KiB) Downloaded 974 times
