Could anyone kindly tell me how to go about Finding text between square brackets, and applying a paragraph style to the text between the brackets (deleting the brackets)?
I'd be most grateful,
Declan
Find Replace query
Re: Find Replace query
Hello Declan,
Here's what it should look like. (I'm using Bold Italic on the replace, but any styles will do.)
- Open Find and set to Powerfind (not Powerfind Pro)
- Type the brackets
- Inside the brackets, put Capture() from the 'Match' menu.
- Inside the Capture() parentheses, put "Any Character" from the 'Wildcard' menu.
- After the "Any Character", put "Shortest 1 or more" from the 'Repeat' menu. (Now you can test the Find to see that it matches what you want.)
- In the replace box, put "Captured 1" from the 'Match' menu
- Select the 'Captured 1' and apply the paragraph style you want to add. Make sure "Replace Attributes" is checked below the replace box.
- Find_in_Brackets.png (45.93 KiB) Viewed 4906 times
Fantastic. Thanks for the step by step instructions.
Declan
Declan
