Change font style and size in multiple files
foster13
Post by foster13 »
Is there a macro or some other means to change the font style and size in multiple files, along the lines of the TextSoap app.? Thank you!
Re: Change font style and size in multiple files
If your font size is set via style, you can adjust the size by replacing the style(s) with style(s) with the same name(s). A good way to do this is to keep different sets of the same styles (same by name, but with different settings) in the Style Library. If you then drag in the set of styles into your document you can easily change them back and forth between different settings.
Unfortunately, however, styles only allow for absolute settings of font size. So even if your styles are all based on Normal style, you can't just change the font size of Normal and have the others (e.g. Heading styles) change proportionally.
