Edit zoom view in multiple files
foster13
Post by foster13 »
How can I change the zoom view to 115% for all files, or all those within any given folder? Thank you!
Re: Edit zoom view in multiple files
Zoom is just another setting that is saved for each file individually. If you change the zoom setting for the Nisus New File all new files will have that setting as default. If you want to change the setting for existing files, I believe the only solution is to open the relevant files, adjust the setting, and save them. Here is a macro that will allow you to choose a group of files and set the zoom for all the files one at a time.
Adjust Zoom for Files.nwm
(3.74 KiB) Downloaded 271 times
