The thesaurus needs improving
greenmorpher
Post by greenmorpher »
As time marches on -- and it does, although, sadly it seems to have moved to at least a jog now and is threatening to break into a full gallop at any time -- my ability to fish words out of my vocabulary when needed has declined.
As a result, I am thrown increasingly on my reference resources, and as a result of that I am finding the Nisus thesaurus wanting more and more often.
This morning, for example, I had too many uses of "major" as an adjective in one sentence. I went to the Nisus thesaurus looking for some alternatives. Bad luck -- not a single reference provided for the use of major as an adjective -- e.g. a major development.
I have had other frustrations of this nature in the past -- in fact, because of that I have not relied on it too much -- but haven’t been as irritated as I was this morning! Perhaps along with loss of capacity to retrieve wanted word, I am getting crotchety too. And perhaps the problems of being on the move, with none of my reference books to hand, and only a chancy and slow internet connection available, are contributing to it.
Whatever -- I feel the thesaurus needs work, preferably quickly so I am still compos enough to to take advantage of it.
Cheers, geoff
Re: The thesaurus needs improving
There is a thesaurus in the System's Dictionary app.
Here is what it gives for 'major' used as adjective:
greenmorpher
Good lord, who would have known? Well, you, obviously, Hamid, but not me! I have never even looked at it. Now it has a place next to NWP in my dock. Many thanks. :)
Cheers, geoff
greenmorpher
Actually, we ought to have a preference to use the OS thesaurus instead of the Nisus thesaurus in the Language panel.
Still, I will just use the contextual menu command "Look up in Dictionary" in future. No biggy, but …
In any case, I will be abandoned on 2.0.7 (on X.6.8) with the next update.
I'll be a norphan! Sigh!
Cheers, geoff
ptram
Post by ptram »
I don't know if I set the shortcut in some ways, but I can invoke the system thesaurus by tapping a word with three fingers. Maybe it's something in the Preferences.
Paolo
Yes, you set it up in the trackpad preferences. I also had a keyboard shortcut set up to invoke it, but I seem to have lost it, or maybe it’s specific to Scrivener, but I tend to use the three-finger tap anyway.
