Kern attribute
msebban
Kern attribute
Post by msebban »
Kern attribute
Kern attribute
capture 5774-02-22 à 21.21.05.png (20.42 KiB) Viewed 5438 times
I'm customizing a special Character for transliteration tab with Kern Attribute in a NWP document.
My character is what i expect (unless i wish to make the Kern stronger) But i want this Kern only for this Character and the ability to paste it by find and replace or one by one to other documents.
The copy function don't allow me to copy my new Character.. So, how can I copy this new character and use it my way (in special characters palette for ex)??
Thank's for answers
Re: Kern attribute
Is it possible for you to use a character style to mark these special characters? (The main drawback is that you may already be using character styles for something else that needs to be applied to such characters…)
Re: Kern attribute
Are you actually making a special character using a custom font and/or the Unicode private use area? Or are you just typing a letter "S" (with combining mark) followed by "h", selecting that, and then tightening the kerning? If it's the latter, then Philip's suggestion to apply a custom character style makes the most sense. NWP can find and replace based on that character style. You could also have a glossary expansion insert that pre-formatted "Sh" combination.
msebban
Re: Kern attribute
Post by msebban »
thank's
it sounds good
