Adding section break via macro
I am trying to create a macro which will take a string in a file exported from Scrivener:
and replace it with a <Section Break : Next Page>.
When I use Find and Replace, enter the appropriate string in the Find box and put the appropriate command from the menu in the Replace box,
Nisus Writer ProScreenSnapz001.jpg (46.72 KiB) Viewed 12753 times
then click "Replace All" it does just what I want.
If I choose "Macroize", it puts the following commands into the macro — copying it to the clipboard reveals this:
Find and Replace '‡‡‡‡‡
', '', 'aU'
When I run that, what I get is <Section Break [No page break]> Can someone tell me how can I make it so that the Macro gives me a page break.
Thanks
Re: Adding section break via macro
Offhand I'm not sure why the macroized version isn't working. It probably has something to do with the way section break characters rely on a hidden attribute to enforce their next page, same page, odd page, etc, status. We'll have to take a look.
In the meantime, the most direct workaround is something like this:
$findWhat = '‡‡‡‡‡
Select Document Start
While Find Next $findWhat
	Menu 'Insert:Section Break:Next Page'
End
Groucho
Post by Groucho »
Hello, Mark.
I wrote this macro years ago. It still works nicely. Last time I used it was yesterday. You can substitute any kind of section break for any placeholder text. Just run it.
Greetings, Henry.
Split into Sections.nwm
(31.5 KiB) Downloaded 1328 times
That's a handy macro Henry, thanks for sharing it.
One irrelevant improvement you could make to reduce the code is changing this:
While Find $tag, 'E'
	if $break == "Next Page"
	elsif $break == "Odd Page"
	Insert:Section Break:Odd Page
	elsif $break == "Even Page"
	Insert:Section Break:Even Page
	elsif $break == "Same Page"
	Insert:Section Break:Same Page
To construct the menu path directly using the user's chosen section break type name:
$menuPath = "Insert:Section Break:$break"
	Menu $menuPath
Groucho
Post by Groucho »
Great help, Martin, thanks. About the menu path, that was something I tried to do but I lacked the skills. I will change the macro.
Greetings, Henry.
