Multipart selection
writerhoward
Multipart selection
Post by writerhoward »
I've followed the NWP manual's direction for doing a multipart selection; however, it's not working. I selected one sentence, then, while pressing A, I tried to select a different, noncontiguous sentence, but as soon as I did that the first selection was deselected. What else do I need to do to make a multipart selection?
I'm using NWP 2.0.4.
Howard
Elbrecht
Re: Multipart selection
Post by Elbrecht »
Howard -
how about "Apple" instead of "A" - the one next to "Space"…
HE
MacBook Pro i9
Tahoe 26.7
NWP 3.4.1
writerhoward
Elbrecht wrote:Howard -
HE
On my keyboard, the Command key is next to the spacebar; however, using the Command key solved the problem. Thank you.
Howard
P.S. The NWP manual needs correction as it states "Press A."
rmark
Post by rmark »
writerhoward,
I'm sorry you experience difficulties with Nisus Writer Pro.
From what you describe, it seems that either there is an error in the User's Guide, or the special font that we use to display the COMMAND key did not work in the PDF (or at least your copy of it). Please let me know on what page of the User's Guide you found the faulty instruction so I can check and, if need be, correct the document.
Write On!
Mark Hurvitz
Nisus Software Inc.
writerhoward
rmark wrote:writerhoward,
Martin,
It's on page 37. See #2 in the image below.
Howard
Screen shot 2013-02-09 at 11.05.30 PM.png (21.34 KiB) Viewed 14443 times
rmark
Post by rmark »
Howard,
Thank you. I see what happened. That "A" lost the special font that should have been applied to it. I'll fix it and we'll post a corrected version shortly.
That should be "Press [COMMAND] as you select each additional…"
Write On!
Mark Hurvitz
Nisus Software Inc.
