adding arrows to image
rben
Post by rben »
I try to add arrow to the image in a certain place, but the arrow stays in the same place. What is wrong?
Re: adding arrows to image
Are you working with Nisus Floating Images?
You will need to pay attention to the anchors of the images. Make sure they are the of the same type ("Moves with paragraph" or "Position on Page of ¶"). If they are of the same type, you can select both together and group them. Then they will stay together.
Hope this helps.
