Superscripted footnote reference in note cut off
mcmattox
Post by mcmattox »
Hello Nisus Folks,
I'm trying to divorce MS Word and have come to Nisus. So far I like it a lot. However, I have a problem that's stumped me. I imported a document into Nisus Writer Pro that has about 40 footnotes. Everything seems ok. Except, where the footnotes appear at the bottom of the page, the first footnote reference number, which is superscripted, is cut off at the top. Here's a screen shot. You can see that the number 32 is cut off at the top.
Screen Shot 2012-07-17 at 8.10.05 AM.png (11.15 KiB) Viewed 2834 times
Thanks for any assistance you can provide.
Re: Superscripted footnote reference in note cut off
We're happy to hear that you're enjoying Nisus Writer! Hopefully we can get this clipped superscripting figured out for you.
There's a variety of reasons your superscripted note reference might be too high, and thus obscured. My best guess would be that you have a fixed line height that is too small to accommodate the display of the note reference. But it's hard to tell from a screenshot. Would you be able to send us a sample document that shows the problem, so we can inspect the settings/formatting directly? The best way is from inside Nisus Writer, via the menu Help > Send Feedback. Thanks!
